Bob Leffler's RV-10
Date:  9-1-2012
Number of Hours:  4.00
Brief Description:  Wing Access Panels
I had to borrow some LPS4-3 rivets from Dana Saucier to complete riveting the supports to the fuselage. I drilled holes on both sides of the fuselage for the CPC connector for the wing electrical connection. I also drilled holes for the for the pitot and AOA lines to enter the fuselage.
I sanded off the primer that I got on the overhead. Unfortunately, I sanded to the final coat into the primer. I'll have to figure out how to repaint.
I also drilled some holes into the hinges for the hinge pin covers.
Left Side
Left Side
Right Side
Right Side
