Bob Leffler's RV-10
RV-10
Door Lock and Cabin Cover
I solved the anti-rotation problem with the door lock. The door lock works pretty good.
I then cut filler pieces out of fiberglass trim pieces and epoxied them in with micro.
Janice worked on sanding the right door frame.
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
