I worked on determining how to install a door lock, which isn't specified in the plans. I had to cut away some of the fiberglass on the interior of the door, which I'll replace after I get the lock working. I have to engineer a solution for the anti-rotation ring. The door handle can cause the lock to rotate when opening. Obviously, that won't work.
Janice worked on sanding the nose wheel some more.
