Bob Leffler's RV-10
RV-10
Cabin Cover & Nose Wheel Pant #2
Pictures are starting to look the same, but they are different pictures every day.
I started out rough sanding the nose wheel pant, then went on to sand the final smooth prime coat on the cabin cover.
Janice finished sanding the nose wheel pant.
They I applied some micro again to the low spots on the nose wheel pant.
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
