Bob Leffler's RV-10
Date:  6-9-2012
Number of Hours:  5.00
Manual Reference:  45-18
Brief Description:  Front Window
45-18, Steps 3, 4, & 5
Brad and Janice assisted me today.
Place the C-1005 Windscreen in place on the fuselage.
Fabricate five clips from pieces of scrap .032 aluminum. The clips are blind riveted to the F-1071 Fwd Fuse Top Skin to hold the base of the C-1005 Windscreen against the fwd fuse top skin. The clips are installed every 12 inches along the lower edge of the windscreen.
Fabricate a Windscreen Base Fairing. The windscreen base fairing provides a smooth transition
between the base of the C-1005 Windscreen and the F-1071 Fwd Fuse Top Skin. The windscreen base fairing is fabricated direclly on the fuselage and consists of a lay-up of E-glass fabric and epoxy resin as subsequenlly described.
I started this step by putting down a layer of micro to fill the gap and smooth the transition between the window and the upper fuselage assembly.
All done
All done
Janice cleaning the glue over run
Brad and Janice cleaning the glue over run
