Bob Leffler's RV-10
RV-10
Rudder trim and cabin cover window brace
I sanded, cleaned, primed, and top coated the front window support brace.
I countersunk the four holes in the cabin cover for the support brace.
I fabricated a bracket to mount the Aerosport rudder trim in the center radio stack insert. I then drilled a hole in the radio stack.
Rudder Trim
Countersunk holes in cabin cover
Sabin cover support brace
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
