Bob Leffler's RV-10
RV-10
Rear Window, Headliner, and Wheel Pants
I trimmed the left rear window and cut some aluminum strips for holding fingers to keep the window in place when adhesive is applied.
I put the left headliner in and marked the final trim lines and drilled the hole for the sholder belt.
Janice worked on the various fairings and wheel pants.
Headliner marked for trimming
Left rear window trimmed
Misc Fairings and Wheel Pants sanded
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
