Bob Leffler's RV-10
RV-10
ELT Bracket
I drilled the mounting holes for the ELT bracket through the bracket and side j-channel. I also had to modify the bracket a bit, since it was a little too large. Once all the holes were drilled, I primed the part.
RV-10 Home
Ailerons
Brakes
Cabin Cover
Control System
Diversions
Doors
Elevator
Flaps
Fuel Tanks
Horizontal Stab
Lighting
Milestones
Panel
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
