Bob Leffler's RV-10
Date:  4-13-2012
Brief Description:  Pull Wiring and NACA Valve Installation
I pulled wire for the NACA Valve Controller, ELT, and Overhead Lighting to the back.
I riveted the mounting bracket onto the NACA Valve Controller.
I cut and installed the SCAT tubing from the NACA vents to the NACA Valve Controller.
I need to get some screen to install over the NACA vent exit.
NACA Valve and SCAT instaleld
Mounting Bracket Riveted
Wire Pulled
Wire Pulled
