Bob Leffler's RV-10
RV-10
Pull Wiring and NACA Valve Installation
I pulled wire for the NACA Valve Controller, ELT, and Overhead Lighting to the back.
I riveted the mounting bracket onto the NACA Valve Controller.
I cut and installed the SCAT tubing from the NACA vents to the NACA Valve Controller.
I need to get some screen to install over the NACA vent exit.
NACA Valve and SCAT instaleld
Mounting Bracket Riveted
Wire Pulled
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
