Bob Leffler's RV-10
Date:  2-25-2012
Number of Hours:  6.00
Brief Description:  Misc Panel
I started the day in putting on the DB-9 F on the wires for the Gemini PFD.
I then cut off the appropriate resistors and/or diodes from the annuciator board to indicate whether or not that particular line was to go low or high to activate the annuciator.
I finished the day cutting holes for both standard and lemo head phone jacks in the armrest pocket and the rear of the armrest. I also installed a cigarette lighter adapter on the rear of the armrest.
I need to install a jack for the second music input, but apparently I forgot to buy one.
That second photo sure looks bad, I guess I didn't get it as clean as I thought I did.
Jacks on the rear of the armrest
Jacks inside the armrest
Gemini PFD connector
