Bob Leffler's RV-10
Date:  12-26-2011
Number of Hours:  4.00
Brief Description:  More wiring and some riveting
I did a variety of tasks today.
I reversed engineered the schematics of the Aerosport Products switches, which took an hour or so. I'll have to talk with Geoff regarding a copule issues
I started to rived the forward edge of the upper fuselage assembly. I was getting tired and decided to finish this task another day.
I pulled the wires through the conduit to the rear door frame for the door close sensor switch. I cut a little hole in the top of the conduit to route these wires to the back of the door where a reed switch will be installed to sense if the door pin is in the proper position.
Left side
Left side
Right side
Right side
Started to rivet the upper fuselage assembly
