Brief Description: Started to install upper fuselage assembly
Brad and I started to install the upper fuselage assembly onto the fuselage. We set the assembly on a couple 2x4s to allow us to work on passing wire through the firewall openings. We also had to install the forest of tabs on the firewall.
I applied a firewall sealer on the leading edge of the upper fuselage assembly to prevent any CO leakage into the cabin. Then we clecoed the upper fuselage assembly to the fuselage. We had a problem with the LPS4-3 that attaches on of the ribs to the firewal support. The LPS rivet wasn't long enough. We had to drill it out and we replaced it with a bolt.
Upper Fuselage Assembly all clecoed
Brad working on passing wires through the firewall
Still quite a few wires to run back through the fuselage
