Bob Leffler's RV-10
Date:  10-23-2011
Number of Hours:  1.00
Brief Description:  Tail weight
I need to create some method to hold the tail down when jacking up the aircraft. I bolted a piece of plywood to a four wheel dolly, then put an eye bolt in the center. I purchased eight concrete blocks for ballast. I think this will be enough, but if it isn't we can easily add more blocks.
