Use the hardware to attach the Cylinder 5 Baffle Assembly and Cylinder 6 Baffle Assembly to the engine.
Match-Drill #12 the two holes in the aft flange of the CB-1007D Aft Center Support Bracket into the CB·1006A Left Aft Case Baffle and the CB-1007 A Right Aft Case Baffle.
Install the two bolts that attach the CB-1007D Aft Center Support Bracket to the CB-1006A Left Aft Case Baffle and the CB-1007 A Right Aft Case Baffle.
Use the hardware to attach the Cylinder 14 Baffle Assemblies to the engine.
