Attach the F-1099B Lower Wing Root Fairing to the T-100SB Shim, T-1001-L Fuel Tank Skin, F-1076 Center Bottom Skin, and to the W-1004-L Bottom Inbd. Wing Skin. Match-Drill #40 and cleco the tank skin at the five locations using the 3/32 holes in the lower wing root fairing as guides.
44-9, Step 1
Align the F-1099A Upper Wing Root Fairing to the inboard edge of the W-1002-L Top Inboard Wing Skin, to the T-1001-L Fuel Tank Skin and to the T-1005-LIT-1005B Tank Attach Bracket and Shim. Inspect the upper wing root fairing in the area of the F-1099C Wing Walk Spacer and adjust the spacer if/as req'd. When satisfied attach the upper wing root fairing. Match-Drill #40 and cleco the F-1099E-L, F-1099F-L, and F-1099H-L Wing Root Fairing Supports and the fuel tank skin using the holes in the upper wing root fairing as guides.
