Bob Leffler's RV-10
Date: 6-19-2011
Number of Hours: 4.00
Manual Reference: 24-3, 44-9, OP34-1
Brief Description: Wing Tip #4, Aileron Trim
24-3, Step 4
Rivet the nutplates to the right wing tip.
44-9, Step 1
I worked for awhile filing the left wing root fairing to make theo edge to fit along the fuselage.
OP38-1, Steps 1, 2, 3
Separate the W-1033A-R and W-1033A-L Aileron Trim Mounting Brackets by removing the shaded areas. Final-Drill the seven 1/8" holes in each of the two aileron trim mounting brackets with a #30 drill, then deburr the holes and any unfinished edges.
With all eight W-1033B Aileron Trim Links still connected, final-drill all sixteen 1/8" holes in the aileron trim links with a #30 drill. Separate the eight aileron trim links by removing the shaded areas, then deburr the holes and any unfinished edges. Prime all parts if/as desired.
Using the hardware called out, assemble the W-1033A-L and W-1033A-R Aileron Trim Mounting Brackets, six W-1033B Aileron Trim Links, and the W-1033C Aileron Trim Arm to create the Aileron Trim Actuation Assembly.
Right Wing Tip nutplates installed
Parts primed
