Bob Leffler's RV-10
Date:  6-6-2011
Manual Reference:  44-6
Brief Description:  Wing Root Fairings
Brad assisted me today.
44-6, Steps 1, 2, & 3
Cleco the F-1099G-L Wing Root Fairing Support to the F-1069-L Fwd Side Skin.
Final-Drill #19 then deburr and dimple a1iS/32 diameter holes in F-1099B Lower Wing Root Fairing.
Attach the F-1099B Lower Wing Root Fairing to the T-1 OOSB Shim, T-1001-L Fuel Tank Skin F-1076 Center Bottom Skin, and to the W-1004-L Bottom Inbd. Wing Skin.
Match-Drill #40 and cleco the tank skin at the five locations using the 3/32 holes in the lower wing root fairing as guides. Final-Drill #19 the same holes.
Unfortunately, a mistake I made over two years ago has come back to haunt me. I have the root fairing shim installed incorrectly. I will have to remove during the next session and re-install. Hopefully I won't have to fabricate new parts. This shim overhangs to the rear, it suppose to overhang forward.
Wing Root Fairing Skins
This it the part that was installed incorrectly.  The overhang is supposed to be forward, not aft.
