Bob Leffler's RV-10
Date:  5-14-2011
Number of Hours:  6.00
Brief Description:  Cabon Cover and Cowl #2
Janice assisted me today with sanding the cabin cover interior.
I sanded the flox edge that was applied in the previous session. I then applied 4 plys of bid fiberglass to support the cowl scoop mod. Additionally, I also applied 4 plys of fiberglass to the area around the spinner and the two forward outside corners. Then added peel ply to all new fiberglass areas. These areas need to be sanded down on the outside to get the cowl flush. These layers will reinforce the areas that will be sanded.
Fiberglass to support the cowl scoop mod
Fiberglass to support the lower cowl spinner area
Cabin Cover filler sanding
