Bob Leffler's RV-10
RV-10
Misc Sub Panel Supports
I worked on the doublers for the comm panel opening in the subpanel. After match drilling the holes, I primed the part, and the riveted them to the subpanel.
I also made some brackets to hang the VP-200 from the ribs behand the subpanel.
I also helped Tom Webster with his annual.
Brackets cut for the VP-200
Primed doublers
Doublers installed
RV-10 Home
Ailerons
Brakes
Cabin Cover
Control System
Diversions
Doors
Elevator
Flaps
Fuel Tanks
Horizontal Stab
Lighting
Milestones
Panel
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
