Bob Leffler's RV-10
Date:  7-20-2010
Number of Hours:  1.00
Manual Reference:  45-16
Brief Description:  Right Door #8
45-16, Step 4
Break apart the C-1013 Gas Strut Attach Bracket into it's two halves and smooth the edges. Insert a C-1016B Bushing in each end of the Bracket Locating Bar and attach the gas strut attach brackets to the bar using the AN3 bolt/washer/nut. Attach the bracket locating bar to the WD-1023 Gas Strut Attach Bracket using the AN3 bolt/washer/nut. Close the C-1002-UR Door and latch it closed. Rotate the bracket locating bar up until the gas strut attach brackets rest against the inner surface of the door. With the gas strut attach brackets held in place, match-drill #30 and cleco to the door using the holes in the gas strut attach brackets as drill guides. Remove the bracket locating bar and remove the gas strut attach brackets and bushings Deburr the holes of the C-1013 Gas Strut Attach Brackets. Prime if/as desired.
I primed the brackets, as well as a couple other pieces.
I was going to put the strut on, but I can't figure out how to compress the strut at the moment.
Match drill the holes and clecoed
Parts Primed
Parts Primed
