Phils Web Site
Date:  11-7-2018
Number of Hours:  6.00
Brief Description:  Left wing
FInished working on the ribs for the left wing. Some were not straight enough. Assembled the wing with clecos and drilled to final size. Disassembled and drilled out the forward tooling hole in the main ribs for wiring for the wing tip. Drilled an additional hole in the ribs for the AOA line to run to the dynon pitot tube. Prepped and primed the main and tip ribs for the left wing.
