Brief Description: Starter, alternator and fuel injector linkage
Designed and fabricated a bracket to hold the mixture cable at the fuel injector/intake manifold. Modified the Skytec NL (heavy duty) starter to clear the air induction snorkle. Vans had indicated the snorkle was designed around the Skytec LS series starters. Also fabricated a support bracket to go between the starter and alternator bracket.
