Phils Web Site
RV9
Worked on fitting the canopy, the worst job on the project. Found the powdercoat on the canopy frame way too thin as you can clearly see the mill numbers on the tubing. Will have to prep and repaint it before final assembly. Poor quality control!
RV9 Home
2163
Ailerons/Flaps
Final assembly
Firewall forward
Fuel system
Fuselage center
Fuselage forward
Fuselage rear
S-19 Home
