Cut the pilot control stick to the proper length. Drilled the stick for the stick grips and wire exit. Snaked the wires through the stick and wired them to a DB9 D-sub connector. Finished running the wires to the control sticks.Tested and everything worked except the switch for the position lights. Diagnosed as the signal wire for the VPX was wrong. I was able to correct it in the software of the VPX.
