Phils Web Site
Date:  10-7-2019
Brief Description:  Fitting the avionics
Spent some time figuring the layout for the avionics components that are located behind the panel. Using Dynon SkyView HDX including two 10 inch panels, radio, transponder, ADSB in, autopilot and engine instruments. Temporarily mounted the components to the sub-panel. We want to get as much of the wiring done before closing up the top of the fuselage.
Rear instrument sub-panel
