As the Matco parking brake valve needed a little more room, I fabricated a bracket to replace the firewall brake line bracket. It moves the valve away from the firewall to allow room for the brake lines. As I am running a fuel injected engine I will not be using the standard Facet electric pump. I fabricated a bracket to hold a -6 bulkhead fitting to bolt to the Facet mount nutplates. I fabricated a 3/8 aluminum line to go from the Airflow Performance injection boost pump the this fitting.
