Remved all the instruments and vents from the panel to allow it to be mounted on the mill. Cut an additional hole next to the radio to mount the Dynon knob panel. This panel allows for direct entry of the altimeter setting as well as adjusting the heading and altometer bugs. Reassembled the vents and ELT control. Had to order some one eared nut plates so the panel can be finished.
