Spent the day wiring the second screen to the first as well as connecting the serial ports as needed. Connected the master relay and installed the diode. Configured the Vertical Power VP-X Sport.
LIT UP THE SCREENS!!!!
At this point the wiring is finally done with the exception of mounting the headset jacks, aux power plugs and the final connections to the wing for the fuel guages and lighting. So far everything works. Tomorrow we will start configuring the Dynon.
