While waiting for parts and tools for the forward sections of the fuselage, We continued work on the tail cone. Got a neighbor to assist with the bending of the lower tailcone sides. Clecoed the stringers and other parts to the sides. When clecoing the stringers and bulkhead parts to the belly skin we discovered that the third bulkhead bottom piece holes do not line up with the holes in the skin. Everything else lines up perfectly. A call to Ed Shwab at Rans found that there was a change in the belly lay out to move the comm antenna from the left side to the right. The entire belly skin with the exception of the third bulkhead is symetrical so flipping the skin works. They discovered that the third bulkhead is not symetrical! They are sending me a new piece that will be match drilled to the skin. Another delay.
