Phils Web Site
S-19
Misc.
Safety wired the 12 exhaust springs and applied high temperature RTV. Pressure tested the coolant system and nothing leaks. Adjusted the nose wheel friction and drilled the spring gear for the cotter pin.
RV9 Home
S-19 Home
2070
Ailerons/Flaps
Final assembly
Firewall forward
Fuel system
Fuselage center
Fuselage forward
Fuselage rear
390
