Phils Web Site
S-19
Balance stabilator
Built a jig to balance the stabilator. Balanced the stabilator and had to remove quite a bit of lead from the weight. Found that a vixen file worked best.
Jig
Stabilator on the jig
Weight after balancing
RV9 Home
S-19 Home
2070
Ailerons/Flaps
Final assembly
Firewall forward
Fuel system
Fuselage center
Fuselage forward
Fuselage rear
390
