Brief Description: Cut prop spinner to clear blades
Spent a couple of hours carefully marking and rough cutting the prop spinner to clear the blades. We will have to do the final trimming to obtain the reccommended 1/8 inch clearance after the attaching screws and nut plates are installed. Also spent some time verifying thaqt all the wiring is functioning. Had a problem with the starter which I found to be my error. Two of the wires on the mag/start switch were on the wrong terminals. The Skyview would not rcognize the oil pressure sender. After reconfiguring the system for the proper sender it would still not see it. After checking the routing og the wires I found one wire on the sender in the wrong location. This was a bit difficult to track down as the Skyview and Rotax manuals are a bit confusing. The Skyview manual shows a drawing of the conector pins that appear to be showing from the pin end and are lettered "A" "B" and "C". The Rotax manual indicates wire colors but there are no wires on the connector. Finally found the connector is marked (very small) "1" "2" and "3". "A" = "1", "B" = "2" and "C"="3". Had the power wire in the wrong hole.
