Finished riviting the wing frame. Test fitted the fuel tank. Began preping the lower wing skin. Had to remove some light corrosion from the skin using Scotchbtite. My understanding is the spots are caused by machining lubricant from the punching process. Rans needs to improve their material handling!!
