Did some additional work on the firewall forward fuel system. Made a jig to hold the nose landing gear leg level and drilled the hole through the nose gear mount and leg. Drilled out and reamed per the manual. Drilled and reamed the lower gear coller to the leg. Removed the leg and primed and painted the leg.
Feels good to have the airplane on all three wheels!!
