Removed the rear spar and de-burred. Riveted the rear spar. Assembled the push-pull tubes for the ailerons. Worked on the aileron bellcranks. Found that the rivet call-out in the plans for the bellcranks did not have adequate grip length. Parts book showed CCPQ41. Needed to use CCPQ 43.
