Finished installing the optional forward inspection panels in the forward side skins. The holes were a bit difficult to cut but I think they will be worth the effort when I have to do any future service on the brake and rudder pedals. Also designed and temporarily installed the parking brake cable anchor by the valve. I purchased the valve from Aircraft Spruce instead of Rans as I would not be using the 1/4 inch brake lines and fittings.
