Began joining the forward section to the center section of the fuselage. Drilled the longerons to the engine mount brackets. Clecoed the forward side skins and checked alignment. All looks good. Considering if I want to add the optional inspection panels to the forward side skins. These would make future brake pedal/master cylinder maintenance much easier!
