Cheetah XLS Web Site
Date:  1-6-2008
Number of Hours:  3.00
Manual Reference:  Engine install
Brief Description:  Engine / electronics
SPECIAL SAFETY NOTE: Be careful to not hook up the solenoid - see photo below to the battery in order to avoid the posibility of accidental starting the motor before the prop is hooked up. This can damage the engine. Jabiru sends the motor with a warning on the starter cable so caution should be made to avoid the possibility of accidentally starting the motor until you intend to.
Boots will be utilized to prevent the possibility of contacting ground to the battery flow to the starter.
Solenoid and regulator mount point
Oil overflow bottle and electric fuel pump
Continuous operation solenoid operated by master switch
