The door frame is designed to be installed without any trimming of the fiberglass. The top door frame is attached in the lower back side with some rivets.
The top of the door frame is riveted to an aluminum frame that sits on the inside bottom root of the wing.
Top door frame - see the bracket the frame is riveted to.
