Cheetah XLS Web Site
Date:  1-1-2008
Number of Hours:  1.00
Manual Reference:  Engine Install
Brief Description:  Engine install details
Note the ground bus. on the inside, the bolt that runs through the firewall will be attached to the ground on the battery in the cockpit, then engine side will attach to the motor mount.
This faston system is available here. http://www.bandcspecialty.com/
Costs quite a bit but is a handy way to make sure you get a good ground system for your entire system.
Ground bus tabs.
Ground bus tabs.
