Cheetah XLS Web Site
Date:  11-8-2007
Number of Hours:  1.00
Manual Reference:  Page 039
Brief Description:  Vertical stabilizer sail installation
The sail came installed, The top tension cables needed to be installed.
This process will require a needle nose pliers or something else to grip the bolt as the tension cables and rudder hinge (Ear Bolt Female #2) is screwed into the bolt on the inside of the sail.
Top tension cables after being installed
Rear view of the top tension cables
