Cheetah XLS Web Site
Date:  11-2-2007
Number of Hours:  0.75
Manual Reference:  Page 025
Brief Description:  Parachute support strut + cockpit diagonal support
The diagonal support tubes were pre assemble and only needed to be installed.
NOTE: it is critical that when building the main fuselage section on page 6 that the holes where the parachute support strut is attached be at the correct angle. It should be installed so that the holes for item 5 on page 25 (Bolt M6X55) is at the correct angle. If installed incorrectly, the holes will angle up to far from the front to the rear. If this happens, you will need to remove the top cross bar on main fuselage section and turn it around.
Parachute support strut and diagonal support tubes
Parachute strut & cockpit diagonal support tubes installed
