Brief Description: Fuselage cross section support struts
Note: if the brackets from Page 13 & 14 are correct, this should take about 45 minutes but we put this together and took it back apart because we had a couple of brackets not installed properly.
Note, the angled bracket is in front of both the verticle and horizontal assembly . the long bolts are used for that one.
