Mark's Web Site
Date:  9-10-2018
Manual Reference:  12-11
Brief Description:  Tail cone install (12-11)
I spent part of the evening getting the rudder back on, which is always a little tricky to get all the washers sandwiched into place. I lifted the front wheel onto a small stool to bring the tail cone down to make it easier to work on the upper bolt. I also finished cutting the slot in the tail cone and installed it. I moved the trim tab to the extreme (up & down) to note the areas that needed a little more trimming. Almost there.
tail cone and rudder installed
still a couple spots that need trimming per 12-10
another view of tail cone install
