Brief Description: Fitting the Wing Walk Doublers (LH)
Fabricated W-727 LH wing walk doubler out of .025 Aluminum sheet. Aligned to main inboard wing skin and match-drilled doubler with the rivet holes on W-702-L main top inboard wing skin as guide. Clecoed the doubler and skin to the wing rib assembly for match-drilling to ribs.
Fabricating LH W-727 wing walk according to dimensions
Match drilling wing walk using top inboard main wing skin as guide
Clecoed Wing walk and Wing Skin to the Wing rib skeleton for match-driling
