Brief Description: Mid Fuselage Skins and Structure
Final-drilled #30 the 1/8" rivet holes that attach the LH and RH F-805G Gussets to the LH and the RH F-805 Bulkheads. Final-drilled #30 the 1/8" rivet holes that attch the F805B-L-1 & -R-1 Floor Support Angles to the LH & RH F-805G Gussets and the F-814C-L-1 & -R-1 Inboard Seat Rib Angles. No pics.
