Worked on the following steps in the Construction Manual:
Cleco together the F-811A-1 & E-1 Bulkheads, the two F-811B-1 Stab Attach Bars, and the F-811C-1 Angle to make an F-811-1 Bulkhead Assembly as shown on DWG 70. NOTE: The F-811A-1 Aft Bulkhead does not have the small tabs at the top. Use a hand seamer to open the bend angle of the flanges on the F-811A-1 Bulkhead so that they are parallel to the flanges on the F-811E-1 Bulkhead. Final-Drill #30, the 1/8 holes common between the F-811A-1 & E-1 Aft Bulkheads. Final–Drill #30, the four 1/8 holes common between the F-811B-1 Stab Attach Bars and the two bulkheads. Match-Drill #30, the remaining holes common between the bulkheads and the stab attach bars. Label the position of the two F-811B-1 Stab Attach Bars on the F-811-1 Bulkhead Assembly. Disassemble the parts from the two previous steps. Deburr the holes and edges of all the F-811 Bulkhead Assembly parts. Prime the two F-811B-1 Stab Attach Bars and the F-811C-1 Angle. Prime the F-811A-1 & E-1 Bulkheads if/as desired. Cleco together the F-811-1 Bulkhead Assembly as shown in the F-811-1 Bulkhead Assembly view on DWG 70. Rivet the five rivet locations that join the F-811A-1 & F-811E-1 Aft Bulkheads to each other.
Clecoed and labeled both F-811B-1 Attach Bars on the F-811-1 Bulkhead Assy.
