DONALD'S WEB SITE
Date:  5-2-2011
Number of Hours:  8.00
Manual Reference:  SNX-F21
Brief Description:  Drilled Tail Cone Bottom Skin / Updrilling
Drilled the bottom tailcone skin to the lower crossties. I had to do it blind, but when I looked afterward the holes in the crossties came out great, probably better than if I'd marked the line positions. I didn't bother since there was not really anything I could do about the hole positions (which are pre-drilled in the skins). Once again, hats off to Sonex and their great plans and parts.
I then started updrilling everything. I stupidly updrilled the righ side rear channel holes whic aren't supposed to be done until the lower hinge is installed, so I'll have to be extra careful not to enlarge those holes when I locate the hinge later. Grr.
