Brief Description: Front canopy drilled and clecoed
After my progress tonight, all but two of the holes have been drilled in the canopy and everything lines up very nicely. The gap between the front and rear frame hoops is as specified and consistent. The hinge system is working as planned and everything latches quite smoothly. Hooray! The final structural piece is the front canopy frame that stiffens the intersection of the front canopy area with the side frames and forward top skin. That will require some careful fitting, and then I can move on to the cosmetic flashing.
